Error: Illegal attempt on RFA log
I got the below error when connecting to ADS with RSSL connection.
Exception Error
AN EXCEPTION HAS BEEN THROWN!  The following information describes the exception:
Exception Type: InvalidConfigurationException
Exception Severity: Error
Exception Classification: ConfigurationError
Exception Status Text: Illegal attempt to create MarketDataSubscriber using RSSL connection type
	Connection name: Connection_SSLED
	Connection type: RSSL
Session: Session1
What is the cause of this error?
treprfarfa-api
From the error, the application uses legacy MD interface (MarketDataSubscriber) which doesn’t support RSSL connection type.
MarketDataSubscriber supports SSLED connection type which uses TCP port 8101 (default port).
\Connections\Connection_SSLED\PortNumber                                                  = 8101
\Connections\Connection_SSLED\UserName                                                     = "<username>"
\Connections\Connection_SSLED\ServerList                                                       = "<hostname>"
\Connections\Connection_SSLED\connectionType                                            = "SSLED"
Therefore, the legacy application (MarketDataSubscriber) can’t switch to RSSL connection type. If the connectionType used by MarketDataSubscriber is RSSL, RFA will generate this log.
To support RSSL connection type, the application must use OMM interface (OMMConsumer). Please refer to the StarterConsumer example in RFA package which shows how to use OMM interface to create a consumer application. Otherwise, you can refer to these online tutorials.
