Is it possible to drill-down into the results of a case?
For example we might have a very common name with several hundred screening results. In this case the World Check One Web Portal allows the user to drill-down into the results by adding additional attributes to the filter (e.g. nationality or date of birth).
We would like to show the user an overview of the results like the Web Portal does (e.g. 200 matches from China, 2 matches from Myanmar, etc) and allow him to drill deeper.
Is there any way to do this over the API without retrieving all profiles (which would take a long time in case of many results)?
