Hi All,
I have tried to run a single name screening in WC1 with Unspecified Entity type selected.
There's an error returned.
Please advise what i have missed .
Please check the screenshot from below for details.
Cheers,
John Chan
Hi All,
Cheers,
John Chan
Looks like issue in our pilot environment only.I tested in UAT environment and it's working fine as expected.
Thanks,
Shilpi
Hi All,
I found out i have no problem to screen the UNSPECIFIED name in another environment.
The only difference is the user role including CaseManager/Screener.
Is it the reason why?
Please advise how to add this role for my ID.
In our pilot environment CaseManager/Screener role was missing.You can add role via below steps
Admin->User->Select The user->Right hand side click the Edit Button.After clicking the edit you can assign a role whatever available in your environment.I have attached the screenshot for pilot environment.
Hope this will help.
Thanks,
Shilpi
Hi Shilpi,
It seems like i have right to screen the case.
But i still got the error message today when i try to screen the name with Unspecified Entity Type.
Cheers,
John Chan
