Results for the same data item come out differently depending on the time range selected.
<br>
I would like to retrieve data for Instrument: 1730.T - Profit and Loss, but it appears that the same data comes out differently, depending on the time period chosen.
I’ve tried below 4 conditions for the same data item;
1) When retrieving the data shortening time range (Attached as Reuter_question1.jpg)
Research and development: no data
Unusual Expense (income): 545000
「Reuter_question1.csv」
import eikon as ek
from datetime import datetime as dt
import pandas as pd
ek.set_app_id('8A74283D221E74D48347816')
fields = ['TR.Revenue.date', 'TR.Revenue', 'TR.GrossProfit']
param = {'SDate': 0, 'EDate': -3, 'FRQ': 'FS'}
if __name__ == '__main__':
    start_date = str(20170701)
    end_date = str(20171005)
    chunk = ['1730.T']
    fields = ['TR.ISOriginalAnnouncementDate', 'TR.ISPeriodEndDate', 'TR.TotalOperatingExpense', 'TR.CostofRevenueTotal', 'TR.SgaExpenseTotal', 'TR.ResearchAndDevelopment', 'TR.UnusualExpense']
    data, error = ek.get_data(chunk, fields, {"SDate": start_date, "EDate": end_date, "FRQ": "FQ", "Period": "FQ0", "ReportingState": "Orig"})
    data.to_csv(path + "Reuter_question1.csv", index=None)
    print(data)
2) When retrieving the data lengthening time range (Reuter_question2.jpg)
Unusual Expense (income): no data
「Reuter_question2.csv」
import eikon as ek
import pandas as pd
    start_date = str(20150101)
    chunk = ['1730.T']
    data.to_csv(path + "Reuter_question2.csv", index=None)
    print(data)
3) When retrieving quarterly data for 30 periods (Reuter_question3.jpg)
Research and development: 22313000.0
Unusual Expense (income): 545000.0
「Reuter_question3.csv」
import eikon as ek
import pandas as pd
    chunk = ['1730.T']
    data, error = ek.get_data(chunk, fields, {"SDate": 0, "EDate": -30, "FRQ": "FQ", "Period": "FQ0", "ReportingState": "Orig"})
    data.to_csv(path + "Reuter_question3.csv", index=None)
    print(data)
4) When retrieving quarterly data for 10 periods (Reuter_question4.jpgreuter-question2.jpg)
「Reuter_question4.csv」
import eikon as ek
import pandas as pd
    chunk = ['1730.T']
    data, error = ek.get_data(chunk, fields, {"SDate": 0, "EDate": -10, "FRQ": "FQ", "Period": "FQ0", "ReportingState": "Orig"})
    data.to_csv(path + "Reuter_question4.csv", index=None)
    print(data)
I think the data below should be right, but how should I fix the program so that no matter what time range I chose I can get the right data?
Unusual Expense (income): 545000 (shown as 0.5)
This is the effect of the issue that's been previously raised and acknowledged on numerous threads on this forum. Null values or data gaps are pushed down to the bottom of the column, thus screwing up the alignment of data between rows and columns. See for example https://community.developers.refinitiv.com/questions/19014/period-end-date-not-pulling-through-properly.html
The issue is still being worked on.
