DSS Rest API: Could not establish trust relationship for the SSL/TLSsecure channel!!
Unhandled Exception: ThomsonReuters.Dss.Api.TransportException: An error occurred while sending the request. ---> System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The underlying connection was closed: Could not establish trust relationship for the SSL/TLSsecure channel. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
at System.Net.TlsStream.EndWrite(IAsyncResult asyncResult)
at System.Net.PooledStream.EndWrite(IAsyncResult asyncResult)
at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar)
--- End of inner exception stack trace ---
dss-rest-apitick-history-rest-api
On 5 Nov 2017, there is a SSL Certificate Update on DSS and TRTH V2.
As part of the 05 November 2017 weekend maintenance activities, Thomson Reuters will update the SSL certificate used to secure the DataScope Select web site and API endpoints. No client action is required; however, clients who use browsers or applications that have strict settings associated with SSL certification should take the necessary action to ensure that the new certificate is accepted. The specific action is dependent on your security settings. Please contact your local IT administrator for assistance.
This may relate to the issue.
For more information, please refer to this product change notification.
