I am trying to download Reuters data into Jupyter notebook. I am importing eikon as ek, setting my ID, and then running the following lines of code:
symbols = ['AAPL.O', 'MSFT.O', 'GOOG.O']
data = ek.get_timeseries(symbols[0],start_date='2016-01-01',end_date='2016-10-31',interval='daily',fields=['*'])
I am then getting the following error. Does anyone know how to solve this?
--------------------------------------------------------------------------- EikonError Traceback (most recent call last) <ipython-input-9-21c64f8a8454> in <module>() ----> 1data = ek.get_timeseries(symbols[0],start_date='2016-01-01',end_date='2016-10-31',interval='daily',fields=['*']) C:\Users\ntopjian\AppData\Local\Continuum\Anaconda3\lib\site-packages\eikon\time_series.py in get_timeseries(rics, fields, start_date, end_date, interval, count, calendar, corax, normalize, raw_output, debug) 153 raise ValueError('corax must be a string') 154 --> 155result = eikon.json_requests.send_json_request(TimeSeries_UDF_endpoint, payload, debug=debug) 156 status_code = get_json_value(result['timeseriesData'], 'statusCode') 157 C:\Users\ntopjian\AppData\Local\Continuum\Anaconda3\lib\site-packages\eikon\json_requests.py in send_json_request(entity, payload, ID, debug) 83 return result 84 if response.status_code == 401: ---> 85raise EikonError('daemon is disconnected') 86 else: 87 raise requests.HTTPError(str(response), response=response) EikonError: 'daemon is disconnected'
