"Request End of Day data for RICs" issue
I am experiencing an issue with the "Request End of Day data for RICs" example within the RESTAPIExampleApplication: the execution flow gets stuck at the following instruction:
var extractionResult = ExtractionsContext.ExtractWithNotes(extractionRequest);
Is someone experiencing the same issue? Thank you for your help
elektron-sdkdss-rest-apidatascope-selectdsspricing
13.7k 26 8 12
@mantonello, I experience the same issue.
Edit:
I just found out there is a Service Alert on TRTH v2, custom extractions issues are being observed. I'll wait for the issue to be solved, and test again before escalating to the dev team.
PS: as a side note, not related to the issue you mention: that request is under the "Tick History" category. As this query is in the DSS forum I guess you are a DSS customer ? If yes (and if you are not also a TRTH customer), then you are not permissioned for TRTH API calls; as a consequence most samples in that category will not work.
@mantonello, the call finally returned data after more than an hour. But if I re-run it now (16:00 GMT) it takes only a few seconds, it looks like the issue has been solved. Can you try again ?
Sorry for the late reply. Yes, it works now.
Thank you very much
