API Not Returning Full Set of Results from Code
eikon-api-script-screen.pngHello,
As part of a research project, I am tasked with pulling date, time, and event data (i.e. event type) for earnings calls put out by a number of different companies dating back to 2001. When I run a query within the regular Thomson Eikon application, I am able to retrieve the data fine. However, when I run the following code through the API, it only returns data dating back ~5 years:
ek.get_data('MMM.N',['TR.EventStartDate','TR.EventType','TR.EventTitle'], {'EventType':'ECall','SDate':'20000101','EDate':'20171001'})
The above is for 3M, but the idea is to be able to utilize a script to get this information as opposed to logging in to Thomson, inputting search criteria, waiting for an excel file to be generated, etc. I have also attached a screenshot of the results for reference. Any ideas or suggestions would be greatly appreciated, as this is my first time working with Python and the Eikon API.
Thanks,
-Chris
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonapifieldsapi-limits
The Web service that returns company events limits the response to a single request to the max timespan of 5 years. If you need events history for a longer period you need to split your request into multiple, each with SDate and EDate parameters no more than 5 years apart.
9.7k 49 38 60
Hi @brunett_chri,
I was able to replicate what you are seeing. As a test, I tried changing the end date to say: '20101001' and noticed the data set returned started at 2005 so it seems the data is there but what is returned is limited.
I will raise the question to the product group.
