Getting historical timeseries FX Rate
I want to get FXRate for a currency to USD for a list of dates. I want the output as a time-series. I can get it currently for a single date using something like this ek.get_data(["GBP="], ['CF_DATE','CF_CLOSE'])
How to convert this into a date range.
Thanks.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonforex
4.6k 26 7 22
You need to use ek.get_timeseries for that such as described here
get_timeseries doesn't return any data, I have tried it several times, it works at times and at times it doesn't not sure why, is there any way using the get_data function?
Hi @sayan.bhattacharjee,
Can you be more specific as to the command you are using?
9.7k 49 38 60
Using the get_timeseries(), this is what I tried:
