I have tried to run the simple code copied from https://github.com/devcartel/pyrfa:
import pyrfa p = pyrfa.Pyrfa() p.createConfigDb("./pyrfa.cfg") p.acquireSession("Session1") p.createOMMConsumer() p.login() p.directoryRequest() p.dictionaryRequest() p.marketPriceRequest("JPY=,EUR=") end = False while not end: try: for data in p.dispatchEventQueue(100): print(data) except KeyboardInterrupt: end = True
However this quickly runs into an error message with the following log file:
RFA Internal failure
Application: python
Process Id: 0x22E8
Thread Id: 0x1640
File: ..\..\..\Logger\Impl\MessageFormatterImpl.cpp
Line: 80
Problem: ::LoadLibrary failed in MessageFormatterImpl::init() for component name "Pyrfa", with logger message file "RFA8_Logger". This message file could not be found. Check component logger configuration. Last error: 126 RFA_VERIFY( 0 ) failed
Stack Trace:
0x000007FEE1022D41 C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd: PyInit_pyrfa() + 203665 bytes
0x000007FEE1024374 C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd: PyInit_pyrfa() + 209348 bytes
0x000007FEE10A547D C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd: trHashingEntityId() + 270557 bytes
0x000007FEE107A0ED C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd: trHashingEntityId() + 93517 bytes
0x000007FEE104E8D3 C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd: PyInit_pyrfa() + 382755 bytes
0x000007FEE0FDD674 C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd 0x000007FEE0FDD89F C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd 0x000007FEE0FF72F3 C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd: PyInit_pyrfa() + 24899 bytes
0x000007FEE1003820 C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd: PyInit_pyrfa() + 75376 bytes
0x000007FEE10038DA C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd: PyInit_pyrfa() + 75562 bytes
0x000007FEE0FF944B C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd: PyInit_pyrfa() + 33435 bytes
0x000007FEE0FF4BA7 C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd: PyInit_pyrfa() + 14839 bytes
0x000007FEE0FF92C2 C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd: PyInit_pyrfa() + 33042 bytes
0x000007FEE100396A C:\Program Files\Anaconda3\lib\site-packages\pyrfa\pyrfa.pyd: PyInit_pyrfa() + 75706 bytes
0x000000001DD15DF8 C:\Program Files\Anaconda3\python35.dll: PyObject_Call() + 120 bytes c:\minonda\conda-bld\work\python-3.5.2\objects\abstract.c, line 2167
0x000000001DDDA3D4 C:\Program Files\Anaconda3\python35.dll: do_call() + 308 bytes c:\minonda\conda-bld\work\python-3.5.2\python\ceval.c, line 4936
Is there anyone who can help me with this?
