Why do nanosecond time fields match OMMTypes.TIME and not OMMTypes.TIME_8
When I compare data.getType() for nanosecond fields they always equal OMMTypes.TIME. I never see time fields equal the 8 bytes type OMMTypes.TIME_8.
Is this correct?
When is OMMTypes.TIME_8 used and when should I test for it?
if( dataType == OMMTypes.TIME ||
dataType == OMMTypes.TIME_3 ||
dataType == OMMTypes.TIME_5 ||
dataType == OMMTypes.TIME_7 ||
dataType == OMMTypes.TIME_8 )
if( dataType == OMMTypes.DATETIME ||
dataType == OMMTypes.DATETIME_7 ||
dataType == OMMTypes.DATETIME_9 ||
dataType == OMMTypes.DATETIME_11 ||
dataType == OMMTypes.DATETIME_12 )
treprfarfa-apitime-stampmifid
11.5k 16 7 10
Hi @sean.mahony
This is an expected behavior. While decoding, the RFA JAVA getType() function will only return TIME. The width specified TIME (like TIME_8) is used ONLY when encoding set definitions (Defined Data).
11.5k 16 7 10
Hi @sean.mahony , what is the version of RFA Java that you are using?
Hi @Wasin Waeosri , I am using 8.1.0.L1
