I have went through the quick start guide and I am getting a login error. The log is attached as well as the Java file.
example100-marketprice-streaminglog.txt
Any assistance will be greatly appreciated.
Hi @aamod,
It appears that you are trying to subscribe via EZD that is not running on a local host,
and that is running on host named "ZAWCAPPOS"?
If this is correct, the username should be the user that was configured during your installation of EZD to be associated with the ILA number, not the ILA itself, for example:
user1, #ILA
should use username("user1"),
for serviceName try "ELETRON_DD" not "EZD".
If this does not help, check EZD log, and optionally enable EZD tracing via configuration.
