The underlying Eikon data services are not available
Anyone come across this exception before, Eikon is running fine, but the Desktop Data API is hitting this exception -
DataServices_CreateError - One or more errors occurred.System.AggregateException: One or more errors occurred. --->
ThomsonReuters.Desktop.SDK.DataAccess.Exceptions.DataServicesException:
The underlying Eikon data services are not available. ---> ThomsonReuters.Desktop.SDK.DataAccess.Exceptions.DataServicesException:
An internal error occured while adding client. Please see server log for more details.
   --- End of inner exception stack trace ---
---> (Inner Exception #0) ThomsonReuters.Desktop.SDK.DataAccess.Exceptions.DataServicesException:
ThomsonReuters.Desktop.SDK.DataAccess.Exceptions.DataServicesException: An internal error occured while adding client.
   --- End of inner exception stack trace ---<---
Any help is much appreciated
eikoneikon-com-apidata
Is Eikon installed on the machine where you are running the code?
Hi Zhenya - yep Eikon was installed and running ok, but they found that re-installing Eikon 'fixed it' - so we are thinking it was configuration related where the settings after re-install makes the Data Services available to the Eikon Desktop SDK.
