Continous Screening date/time range issue related to time zones
Starting June 6th a client in Europe running our code has been having issues with SO returning an error that continuous screening is returning an invalid date range. The problem appears to be that the request is being built based on the current date/time where the client is (UTC+2), but the SO server is complaining that the request is asking for 2 hours more data than what SO has. The code is converting local time to London time so it is currently sending UTC+2 as the time. Note that prior to June 6th, everything worked and there were no time changes that I'm aware of.
Basically it looks like SO is expecting the actual current UTC time not the current local time converted to UTC (I believe the London time zone in the code is wrong) . Is that the case or is something else wrong?
world-checkscreeningscreening-api
Actually looking at this more, I'm fairly certain the code is wrong. The documentation says to send GMT time and the code is sending London time, which would be wrong during DST. The thing that is puzzling is that DST starts in March in Europe. This problem started in June.
