How to call Adinterp in VBA code
Hi tried to write a user-defined function which uses AdInterp function.
An error occurred when I tried to load the AdfinXanalystics module with the below code:
Set CreateAdxUtilityModule = CreateReutersObject("AdfinXAnalyticsFunctions.AdxUtilityModule")
The error message is "File not found: PLVbaApis.dll"
Please kindly help. Thanks!
eikoneikon-com-apivbaADH
A few questions:
  1. Are you running this code in Eikon Excel?
  2. If yes, is Eikon Excel signed in to the platform?
  3. Could you show me your CreateReutersObject function declaration please?
Function InterpCGB(yr As Integer) As Double
Dim r As Long
r = ActiveCell.Row
Dim y As Double
Dim ws As Worksheet
Set ws = ActiveSheet
Dim ZcDates As Variant
Dim ZcRates As Variant
ZcDates = Array(1, 3, 5, 7, 10)
ZcRates = Array(ws.Cells(r, 2).Value, ws.Cells(r, 4).Value, ws.Cells(r, 6).Value, ws.Cells(r, 8).Value, ws.Cells(r, 10).Value)
'Set CreateAdxUtilityModule = CreateReutersObject("AdfinXAnalyticsFunctions.AdxUtilityModule")
y = CreateAdxUtilityModule.AdInterp(yr, ZcDates, ZcRates, "IM:CUBR")
InterpCGB = y
End Function
Sub test()
MsgBox InterpCGB(Range("K4").Value)
End Sub
Hi Zhenya I posted my code above. For your questions:
1) yes
2) yes
3)
#If VBA7 Then
Public Declare PtrSafe Function CreateReutersObject Lib "PLVbaApis.dll" (ByVal progID As String) As Object
#Else
Public Declare Function CreateReutersObject Lib "PLVbaApis.dll" (ByVal progID As String) As Object
#End If
Public Function CreateAdxUtilityModule() As AdfinXAnalyticsFunctions.AdxUtilityModule
End Function
PS it worked on my colleague's PC.
Thanks!
Hi @shelley.y.wang
I don't see anything wrong with your code, which is further evidenced by it having worked on another machine. So, the issue you experienced must be machine specific. Let's start with a quick sanity check. You do have Eikon installed on this machine, right? If you search in the Eikon install folder you can find PLVbaApis.dll file, correct?
Which version of Excel do you use? In particular I'm interested if it's 32-bit or 64-bit?
Hi
1) Yes Eikon installed
2) Yes PLVbaApis.dll exists in my active installation folder
3) I'm running office 2007 so I'm assuming its 32bit. My PC system type is 64bit. The exact MS office version is 12.0.6612.1000
@shelley.y.wang what about if you try to build a Eikon Excel formula using the formula builder? Does it work?
