Read timed out Error
While retrieving data with ek.get_data() sometimes I get error:
ReadTimeout: HTTPConnectionPool(host='localhost', port=36036): Read timed out. (read timeout=60)
What is the best way to hadle it?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythontime-out
4.3k 2 4 5
Some requests can spend more than 60 seconds to resolve by the platform and/or due to a low network bandwidth.
You can increase the timeout with the function ek.set_timeout before calling ek.get_data()
Thank you! I'll try this option.
Also I've noticed that restarting of Eikon API Proxy helps.
Can it be that sometimes API is overloaded? E.g. yesterday and today (18/09 and 19/09) data retrieving takes too much time and I get ReadTimeout errors often. I use ek.set_timeout but it doesn't seem to help much.
