Throughput & latency testing
I am experimenting with different RFA Consumer configurations, that is Callback model vs eventqueue usage, combining with Dual thread model and other settings. The aim is to improve handling large burst scenario. Is there a test tool/idea that can simulate RFA message burst to allow test of different configuration and setting?
treprfarfa-apiperformance
Hi @s.tang
Have you referred to the PerfTools folder of your RFA Dev Kit? And also the Perf Tools Guide pdf files that come with each RFA kit? i.e. RFANET OpenSourcePerfToolsGuide, RFAJ OpenSourcePerfToolsGuide or RFA OpenSourcePerfToolsGuide
So, for example you could connect you consumer app to the Perf Interactive Provider tool and configure the provider to send varying sizes of bursts of data.
If the above cannot provide the kind of test scenarios you require, then your Market Data team should also have access to some performance test tools that come packaged with the TREP components e.g. 'sink_driven_src'. If not, then they should be able to download these from our Customer Zone - I believe the package is called Infra Tools.
