When we really need an ongoing screening? Is Screening only not enough?
I am wondering why we need two types of screening. Can someone please explain what actually "ongoing screening" meant?
world-checkworld-check-onescreening
Hi @baskaran.subramanian,
  • The World-Check One API provides the ability to screen entity names, with or without secondary fields such as date of birth for individuals. These names are called “cases” within the World-Check One system.
  • The ability to retrieve results of the screening process from the World-Check database
  • The ability to flag cases for Ongoing Screening, and retrieve the World-Check results from the Ongoing Screening process.
Enable Ongoing Screening for the Case identified by the given caseSystemId. This will schedule the Case to be re-screened periodically by the system.
If a case is set to have ongoing screening then the system will automatically re-screen the case against all updates and changes to the World-Check dataset every day. If you are using the API then you will need to ask for the screen result.
Hope this will help.
Thanks,
Shilpi
