Retrieve Date of Birth for Individual
Hi there,
Is it possible to display the Date of Birth for an IndividualEntity in Worldcheck One? I can see that the Age field is available for an Entity but I see nothing for the Date of Birth.
It looks like I may be able to retrieve a Date of Birth from Result SecondaryFields but this only seems to be populated if the user enters a Date of Birth when searching - is that correct?
world-checkworld-check-one
3.1k 16 7 7
Hi @stephen.davidson
If you enter the DOB secondary field in your case creation, then yes the screening will show the DOB of the matches in the secondaryFieldResults[].
If you do not enter a DOB, then you need to request the World-Check One profile and get the events[] array, type BIRTH
Brian
Excellent - many thanks indeed.
