iplot doesnt work
I am struggling with to run a piece of code of the INTRODUCTION TO EIKON WEB AND SCRIPTING API webinar.
import eikon as ek
ek.set_app_id('xxxxxxxxx')
msft=ek.get_timeseries('MSFT.O',fields='CLOSE',start_date='2015-06-23',end_date='2017-06-23')
import cufflinks
msft.iplot(kind='line',color='blue',bestfit=True)
returns
Aw, snap! We don't have an account for ''. Want to try again? You can authenticate with your email address or username. Sign in is not case sensitive.
Don't have an account? plot.ly
Questions? support@plot.ly
PlotlyError                               Traceback (most recent call last)
<ipython-input-12-df8fac0cd8d5> in <module>()
----> 1msft.iplot(kind='line',color='blue',bestfit=True)
C:\Users\koflerma\AppData\Local\Continuum\Anaconda3\lib\site-packages\cufflinks\plotlytools.py in _iplot(self, data, layout, filename, sharing, kind, title, xTitle, yTitle, zTitle, theme, colors, colorscale, fill, width, dash, mode, symbol, size, barmode, sortbars, bargap, bargroupgap, bins, histnorm, histfunc, orientation, boxpoints, annotations, keys, bestfit, bestfit_colors, mean, mean_colors, categories, x, y, z, text, gridcolor, zerolinecolor, margin, labels, values, secondary_y, secondary_y_title, subplots, shape, error_x, error_y, error_type, locations, lon, lat, asFrame, asDates, asFigure, asImage, dimensions, asPlot, asUrl, online, **kwargs)
   1043                 return py.plot(figure,sharing=sharing,filename=filename,validate=validate,auto_open=False)
   1044         else:
-> 1045return iplot(figure,sharing=sharing,filename=filename,validate=validate,online=online)
   1046
   1047
C:\Users\koflerma\AppData\Local\Continuum\Anaconda3\lib\site-packages\cufflinks\plotlytools.py in iplot(data_or_figure, validate, sharing, filename, online, **kwargs)
   1187                         filename='Plotly Playground {0}'.format(time.strftime("%Y-%m-%d %H:%M:%S"))
   1188 		return py.iplot(data_or_figure,validate=validate,sharing=sharing,
-> 1189 						filename=filename)
   1190
   1191 def _ta_figure(self,**kwargs):
C:\Users\koflerma\AppData\Local\Continuum\Anaconda3\lib\site-packages\plotly\plotly\plotly.py in iplot(figure_or_data, **plot_options)
    156         embed_options['height'] = str(embed_options['height']) + 'px'
    157
--> 158return tools.embed(url, **embed_options)
    159
    160
C:\Users\koflerma\AppData\Local\Continuum\Anaconda3\lib\site-packages\plotly\tools.py in embed(file_owner_or_url, file_id, width, height)
    388         else:
    389             url = file_owner_or_url
--> 390return PlotlyDisplay(url, width, height)
    391     else:
    392         if (get_config_defaults()['plotly_domain']
C:\Users\koflerma\AppData\Local\Continuum\Anaconda3\lib\site-packages\plotly\tools.py in __init__(self, url, width, height)
   1363         def __init__(self, url, width, height):
   1364             self.resource = url
-> 1365self.embed_code = get_embed(url, width=width, height=height)
   1366             super(PlotlyDisplay, self).__init__(data=self.embed_code)
   1367
C:\Users\koflerma\AppData\Local\Continuum\Anaconda3\lib\site-packages\plotly\tools.py in get_embed(file_owner_or_url, file_id, width, height)
    293                 "'{1}'."
    294                 "\nRun help on this function for more information."
--> 295                 "".format(url, plotly_rest_url))
    296         urlsplit = six.moves.urllib.parse.urlparse(url)
    297         file_owner = urlsplit.path.split('/')[1].split('~')[1]
PlotlyError: Because you didn't supply a 'file_id' in the call, we're assuming you're trying to snag a figure from a url. You supplied the url, '', we expected it to start with 'https://plot.ly'.
I have to admit that a am not overly familiar with Jupyter.
Thanks in advance!
Hi @m.kofler
As mentioned on the webinar - I use cufflinks which is a library based on plotly. This is not created/supported by Thomson Reuters. You can see a tutorial of how to setup your plot.ly account here.
Followed the steps and works, cheers Jorge!
The 'cufflinks' pacakge makes use of 'plot.ly'. It looks like this has to do with using online vs. off-line methods of plot.ly. Could you restart your kernel and try again?
Could you help @jorge.santos ?
Thanks Joris. Have restarted, but no luck
9.7k 49 38 60
Hi @m.kofler,
You have to explicitly go offline when using cufflinks if you don't have an account. For example:
import cufflinks as cf
cf.go_offline()
Worked. Many thanks Nick!
@m.kofler: Please see iPython notebooks at TR samples github site, which have working samples using plotly and cufflinks.
Another sample.
