hi
I compiled "RFA .NET Tutorials\step8\MRNExample_VS120.sln", with visual studio 2013
updated below stuff
*** file "ExampleRFA.cfg"
\Connections\Connection_RSSL\rsslPort = "MY_PORT"
\Connections\Connection_RSSL\hostName= "MY_HOST"
*** source code : "RFA .NET Tutorials\step8\RDMExample.cs"
private static readonly RFA_String UserName = new RFA_String("MY_ACCOUNT");
private static readonly RFA_String ServiceName = new RFA_String("MY_SERVICE");
private static readonly RFA_String ItemName = new RFA_String("EUR=");
can connect to the server, but failed to login (Login Denied, NotAuthorized).
could you advise??
thanks
log:
2017/07/10 10:26:02.788 INFO : <- Received LoggerNotifyEvent:
[Mon Jul 10 10:26:02 2017]: (ComponentName) Static: (Severity) Information: Connection Status Changed, RSSL_Cons_Connection "Default::Connection_RSSL MY_HOST:MY_PORT" State: "Up" StatusCode: "None" StatusText: Connection up
2017/07/10 10:26:03.022 INFO : <- Received ConnectionEvent:
Connection Connection_RSSL is UP!
********************* ERROR! ********************** ERROR! *********************
2017/07/10 10:26:03.022 ERROR* : <- Received MMT_LOGIN - Login Denied
streamState : Closed
dataState : Suspect
statusCode : NotAuthorized
statusText : A21: A required argument was NULL
2017/07/10 10:26:03.022 INFO : <- Received Event Stream Closed Event, event type: OMMItemEvent handle: 472504528
2017/07/10 10:26:03.178 INFO : <- Received LoggerNotifyEvent:
[Mon Jul 10 10:26:03 2017]: (ComponentName) Static: (Severity) Information: RSSL Channel closing on connection "Default::Connection_RSSL MY_HOST:MY_PORT" due to "requested disconnect"
