Name Transposition
I am wondering if the Worldcheck API supports Name Transposition. I see some mention in the documentation around Audit events however I don't see it as an option on the screening request.
world-checkworld-check-one
As per the above
3.1k 16 7 7
Hi @ian.bartrum,
The WC1 API does not support case creation with Name Transposition through the API.
However, if a case is created through the WC1 Application with Name Transposition turned ON, then the API will continue to use Name Transposition when screening the case. So Name Transposition is a case creation screening type selection, and case creation with Name Transposition selected through the API is not available yet.
Brian
Hi @ian,
If you are using postman collection,then using SEQ-4a(screening request) you can able to screen a case means screening a request.For this request you have to update the case-system-id for that particular case, for which you want to send the request via environment variable.Once you screen the case successfully,it will appear WC1 API also.
Hope this will help .
Thanks,
Shilpi
Hi @saha.shilpi1 ,
Sorry your answer makes no sense. I have no problem screening a name - I want to know specifically if there an option for Name Transposition as part of the screening request.
Ian
Hi @ian,
May be my understanding is wrong.Will check if it's possible or not .
Thanks,
Shilpi
