We would like to know if there is an alternative and to not do select calls?
We would like to know if Reuters is adding a socket to select list for sockets descriptors greater than or equal to 1024?
As shown below in the threading and strace output we believe this is causing us issues:
Thread output:
#20x00007f5ab6c4c71e in onload_select (nfds=1024, rds=0x7f59621fafe0, wrs=0x7f59621faf60, exs=0x7f59621faee0, timeout=0x7f59621fb060) at ../../../../../src/lib/transport/unix/sockcall_intercept.c:1160
lib_context = {thread = 0x7f59621fbb20, saved_errno = 115}
timeout_ms = 1
used_ms = 0
rc =
#30x00007f5aa8385e17 in RTRSelectNotifier::enable() () from /opt/srlabs/smds/builds/ms-eur-smds-4.0.8.700//md-3rd/reuters_mapi/libs751/RHEL5_64_GCC412/libRFA_SessionLayer.so
No symbol table info available.
#40x00007f5aa836d09f in rfa: (worry) essionLayer: (worry) essionImpl::runThread() () from /opt/srlabs/smds/builds/ms-eur-smds-4.0.8.700//md-3rd/reuters_mapi/libs751/RHEL5_64_GCC412/libRFA_SessionLayer.so
#50x00007f5aa8d55f27 in rfa: (worry) upport::Thread: (worry) tartWrapper(void*) () from /opt/srlabs/smds/builds/ms-eur-smds-4.0.8.700//md-3rd/reuters_mapi/libs751/RHEL5_64_GCC412/libDacs.so.7
#60x0000003bb36079d1 in start_thread () from /lib64/libpthread.so.0 No symbol table info available.
#70x0000003bb32e88fd in clone () from /lib64/libc.so.6 No symbol table info available.
strace output:
No Title
[a.bhise@dnjsvdev03v 0630_mergedProfile_TCP_Not_Acclerated_Breaks]$ grep "10.175.181.40" strace.out
23879 14:13:16.527338 connect(1030, {sa_family=AF_INET, sin_port=htons(14002), sin_addr=inet_addr("10.175.181.40")}, 16
23879 14:13:31.553478 connect(1131, {sa_family=AF_INET, sin_port=htons(14002), sin_addr=inet_addr("10.175.181.40")}, 16
23879 14:13:46.565700 connect(1083, {sa_family=AF_INET, sin_port=htons(14002), sin_addr=inet_addr("10.175.181.40")}, 16
23879 14:14:01.582052 connect(1162, {sa_family=AF_INET, sin_port=htons(14002), sin_addr=inet_addr("10.175.181.40")}, 16
23879 14:14:16.599886 connect(1175, {sa_family=AF_INET, sin_port=htons(14002), sin_addr=inet_addr("10.175.181.40")}, 16
23879 14:14:31.612650 connect(1191, {sa_family=AF_INET, sin_port=htons(14002), sin_addr=inet_addr("10.175.181.40")}, 16
23879 14:14:46.625023 connect(1203, {sa_family=AF_INET, sin_port=htons(14002), sin_addr=inet_addr("10.175.181.40")}, 16
23879 14:15:01.642350 connect(1213, {sa_family=AF_INET, sin_port=htons(14002), sin_addr=inet_addr("10.175.181.40")}, 16
23879 14:15:16.667858 connect(1219, {sa_family=AF_INET, sin_port=htons(14002), sin_addr=inet_addr("10.175.181.40")}, 16
Also Just to add some context here, we are seeing reuters making select calls and adding socket to FD_SET higher than 1024. If the library attempts to add an fd that is greater than the limit to the fdset then the behaviour is undefined, and won't necessarily result in what's being passed to the select call itself being wrong, but could, for example, result in other memory in the application being corrupted. Unfortunately, because this happens at fdset creation, so before the call to select, it's not visible at the point at which onload sees the select call, so we can't add instrumentation that would detect this.
That means that we need confirmation from the library whether it may be violating the restrictions on the use of fdset. So it would be helpful if you could confirm with the providers of the library whether or not they may be passing an invalid value to FD_SET.
