Updates to the API
Is there a Blog or notification system for when the API is updated? It would seem there has new property added to the API with no notification in the last month or so? This change broke our integration but would have been an easy fix if we have prior knowlege
world-checkworld-check-one
3.1k 16 7 7
Hi @stephen.davidson,
Can you be more specific, what change broke your integration?
Thanks,
Brian
There is structure called Entity, and in there a list of CountyLinks each consisting of country, countryText and type. type was defined as one of NATIONALITY, OPERATESIN, POB, POD, REGISTEREDIN, RESIDENT and VESSELFLAG. The problem today was due to the fact, that data retrieved contained brand new value for type=LOCATION
This meant our deserialiser failed.
Would this type fo thing be documented in the change log? Is there a change log?
Hi
Yes we have just encountered the same problem as well. Please clarify?
