RFAJ gives "Released MSG into wrong OMMPool" error message on the encoder.initialize call
Simple OMM Posting consumer application; first POST works, in preparing the next post the call to encoder.initialize gives this error
com.reuters.rfa.omm.OMMException
: Released MSG into wrong OMMPool
at com.reuters.rfa.internal.rwf.RwfPool.release(Unknown Source)
at com.reuters.rfa.internal.rwf.RwfEncoder.clear(Unknown Source)
at com.reuters.rfa.internal.rwf.RwfEncoder.initialize(Unknown Source)
which I cannot find documented anywhere
treprfarfa-apiOMMposting
Finally tracked this down. I was releasing the POST message to the pool
OMMMsg msg = (OMMMsg) encoder.getEncodedObject();
ommpool.releaseMsg(msg);
This then caused an exception the next time I tried to call
encoder.initialize(OMMTypes.MSG, 1000);
Hi @alan.bain
Can you recreate this using one of our RFA Java examples e.g. com.reuters.rfa.example.omm.postingConsumer ?
I have a vague recollection of another developer having a similar issue when they had acquired two OMMEncoders and accidentally transposed them in his code in one location.
e.g. the above example has a _payloadOMMEncoder and _postOMMEncoder declared....
It's definitely the same encoder & pool being used in both times. I don't have the separate _payload and _post encoders. Turning on IPC tracing I see the first message going out
---DATA TRACE---
MESSAGE
Msg Type: MsgType.POST
Msg Model Type: MARKET_PRICE
Indication Flags: POST_INIT | POST_COMPLETE
Hint Flags: HAS_ATTRIB_INFO | HAS_SEQ_NUM | HAS_PUBLISHER_INFO
SeqNum: 1
Publisher Address: 0xa65fce0
Publisher Id: 18028
AttribInfo
ServiceId: 8032
NameType: 1 (RIC)
Payload: 44 bytes
FIELD_LIST
FIELD_ENTRY 2: 40
FIELD_ENTRY 4: 02
FIELD_ENTRY 38: 190c07d8
FIELD_ENTRY 22: 40a317999999999a
FIELD_ENTRY 25: 40a3180000000000
Can I get the source code to reproduce this problem in my environment?
