I have a problem in installing eikon python api .
I downloaded the code and went to setup.py and clicked on it,iIopened and disappeared before I could type the command what am I doing wrong here
4.3k 2 4 5
If you install eikon Python API from the code, you have to type "python setup.py install" in a command prompt.
you mean going to python command and type in this instructions
Open a Windows command prompt then launch the command in eikon source directory :
C:\DEV\eikon> python setup.py install
running install
Finished processing dependencies for eikon==0.1.9
C:\DEV\eikon><br>
If you just want to use the API, you don't have to download sources.
You can install it in your Python library cache with the "pip install eikon".
