EMA Issue with update items
We are currently facing an issue with EMS service , where in , we received the refresh messages properly for all subscribed items , but , post that , update messages were not received by the application.
at 11:12 : We stopped receiving update items.
We had raised the issue with TR support and they had checked ADS logs with the below findings,
11:19 : Warning Output threshold breached for EMS_ID at position X.x.x.x on host abc using application on channel xx.
11:20 : RSSL disconnect from "EMS_ID" at position "x.x.x.x" on host "abc" using application "" on channel xx. Reason: User using application on channel xx has been disconnected due to an overflow condition.
But during all these , the EMA log had no events logged , We have earlier observed that , if there is any disconnection , the event is logged in EMA log and re-connection happens internally by EMA Cpp library.
During all the time , we checked the connection to RSSL port 14002 and the connection was in ESTABLISHED state only .
Kindly help resolve this .
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apiADSrssl
@yajnasteju
When the connection has been disconnected, EMA will recover the connection and item requests on behalf of the application. Moreover, the EMA log will report the channel down message, as shown below.
loggerMsg
    TimeStamp: 09:54:04.387
    Severity: Warning
    Text:    Received ChannelDownReconnecting event on channel Channel_1
	Instance Name Consumer_1_1
	RsslReactor 0x00000000005EA050
	RsslChannel 0x00000000005EA050
	Error Id -1
	Internal sysError 10054
	Error Location ..\..\..\ValueAdd\Reactor\Impl\rsslReactor.c:3140
	Error Text <..\..\..\Ripc\Impl\ripcsrvr.c:6820> Error:1002 ripcRead() failure. System errno: (10054)
loggerMsgEnd
loggerMsg
    ClientName: LoginCallbackClient
    Severity: Warning
    Text:    RDMLogin stream state was changed to suspect with status message
	username user
	usernameType 1
	position 127.0.0.1/net
	appId 256
	applicationName ADS
	instanceId <not set>
	singleOpen 1
	allowSuspect 1
	optimizedPauseResume 1
	permissionExpressions 1
	permissionProfile 0
	supportBatchRequest 1
	supportEnhancedSymbolList 1
	supportPost 1
	supportViewRequest 1
	role 0
	State: Open / Suspect / None / 'Channel is down.'
loggerMsgEnd
The severity level of the channel down log is LoggerSeverity::Warning (2). Therefore, to get the channel down log, the LoggerSeverity configuration of the channel must be LoggerSeverity::Verbose (0), LoggerSeverity::Success (1), or LoggerSeverity::Warning (2).
<Logger>
	<Name value="Logger_1"/>
	<!-- LoggerType is optional:  defaulted to "File" -->
	<!-- possible values: Stdout, File -->
	<LoggerType value="LoggerType::File"/>
	<!-- LoggerSeverity is optional: defaulted to "Success"	-->
	<!-- possible values: Verbose, Success, Warning, Error, NoLogMsg-->
	<LoggerSeverity value="LoggerSeverity::Success"/>
</Logger>
As mentioned in the question itself , None of the events were logged in EMA log.
Below is the logger config;
<Logger>
<FileName value="reuters"/> <LoggerSeverityvalue="LoggerSeverity::Success"/> <IncludeDateInLoggerOutput value="1" />
</Logger>
We have earlier observed these channel down and reconnect logs , but during this particular issue , no such events were recorded.
@yajnasteju
Could please share the TREP log and EMA log when the problem occurred?
There is nothing logged in EMA log during the issue. The last log written was on Successful Login .
loggerMsg TimeStamp: 2017/05/25 07:15:01.392 ClientName: ChannelCallbackClient Severity: Success Text: Received ChannelUp event on channel TR_TestVPN_Channel1 Instance Name Consumer_1_1 Connected component version: ads2.6.11.L1.linux.tis.rrg 64-bit loggerMsgEnd
