Hi Sir
We would like to use one of the following RFA C++ on RHEL 7.x platform.
Please tell us when you any plan to support RHEL 7.x for the near future.
RFA C++7.6(OMM)
RFA C++7.6(non-OMM)
RFA C++8.0
You should be able to use RFA C++ OMM interface from RFA 8.x or 7.6.2 package on RHEL7. This is because it support Oracle Linux 7 accroding to API Compatibility Matrix.
As far as I understand Oracle Linux is fully compatible – both source and binary – with Red Hat Enterprise Linux according to the following document from Oracle website. You might use RFA library from folder <RFA Installation Path>/Libs/OL7_64_GCC482 to build the application.
However when you have a case raise to RFA Support, we will try to replicate and investigate the issue using Oracle 7 instead.
