Drop a SYMBOL_LIST from the ADH
I want to remove some items from an ADH cache.
  • adhmon -removeItem is working fine for the MARKET_PRICE.
  • But it's not working with the SYMBOL_LIST.
When I use "-removeItem" against a SYMBOL_LIST named MyRic, I have this error message in the adh.log:
<xxxxx.gp.adh.2.sourceThread.serviceGenerator.XXXX: Info: 2017-05-23.14:46:14> Cannot remove item (MyRic MARKET_PRICE) as item does not exist.<END>
Any idea?
elektronrefinitiv-realtimetrepsymbologyinfrastructureADH
Hi @nicolas.roux
As per the warning message, it is trying to drop a MARKET_PRICE domain item MyRic because that is the default domain.
According to the ADH manual, you can specify a domain if you want to drop an item which is not MARKET_PRICE
adhmon -instance instance_ID [-removeItem [[routeName] serviceName] [\"]item_name[ D:domain\"]] | [-removeItems filename]
Note: If using the domain specifier with the item_name, the entire item_name and domain specifier (D:domain) must be encapsulated in quotes. If you're using a Unix type platform, be sure to escape the quote sequence, otherwise the Unix shell removes them when parsing the options. A space character separates the item_name and D:domain
I cannot test this at present so I cannot confirm if the Domain will be the name 'SYMBOL_LIST' or the numeric ID of '10'.
You can find further notes in the ADH Install guide section '17.3.6 Using adhmon to Drop Items'
It's working perfectly fine. Thanks a lot!
