I am currently stuck with the below issue in my environment. Could you please help to check if there is any way to resolve it. The Java code posted worked on my Windows environment, but the same code is not working on my Unix environment.
I am trying on my end to check for solutions.
javax.net.ssl.SSLPeerUnverifiedException: Certificate for <159.220.25.95> doesn't match any of the subject alternative names: [*.thomsonreuters.com] [5/19/17 22:15:02:394 CST] 0000002e SystemErr R at org.apache.http.conn.ssl.SSLConnectionSocketFactory.verifyHostname(SSLConnectionSocketFactory.java:467) [5/19/17 22:15:02:395 CST] 0000002e SystemErr R at org.apache.http.conn.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:397) [5/19/17 22:15:02:395 CST] 0000002e SystemErr R at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:355) [5/19/17 22:15:02:395 CST] 0000002e SystemErr R at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
Thank you,
John
