We have noticed an issue with a provider we have written with the JAVA RFA API 7.2.1. We are using a custom domain model (128) and when we send UPDATE_RESP messages through our TREP the AttribInfo is being stripped off. REFRESH_RESP messages traverse the TREP without modification.
Successful REFRESH_RESP
Provider sends
MESSAGE Msg Type: MsgType.REFRESH_RESP Msg Model Type: Unknown Msg Model Type: 128 Indication Flags: REFRESH_COMPLETE | CLEAR_CACHE Hint Flags: HAS_ATTRIB_INFO | HAS_ITEM_GROUP | HAS_QOS | HAS_RESP_TYPE_NUM | HAS_STATE State: OPEN, OK, NONE, "OK" Qos: (RT, TbT) Group: 0001 RespTypeNum: 0(REFRESH_SOLICITED) AttribInfo ServiceId: 417 Name: EXCH_STATUS NameType: 1 Payload: 11 bytes FIELD_LIST FIELD_ENTRY 20002: 01
Client receives
Unsuccessful UPDATE_RESP
Provider sends
MESSAGE Msg Type: MsgType.UPDATE_RESP Msg Model Type: Unknown Msg Model Type: 128 Indication Flags: Hint Flags: HAS_ATTRIB_INFO | HAS_RESP_TYPE_NUM RespTypeNum: 0 AttribInfo ServiceId: 1 Name: EXCH_STATUS NameType: 1 Payload: 11 bytes FIELD_LIST FIELD_ENTRY 20002: 02
Client receives
MESSAGE Msg Type: MsgType.UPDATE_RESP Msg Model Type: Unknown Msg Model Type: 128 Indication Flags: Hint Flags: HAS_RESP_TYPE_NUM RespTypeNum: 0 Payload: 11 bytes FIELD_LIST FIELD_ENTRY 20002: 02
As you can see the AttribInfo has disappeared.
Does anyone have an idea as to what is going on?
