9.7k 49 38 60
WebSocket API C# example throws exception with batch request
Using the packaged example application written in C# that fetches a batch of items works based on the small sample data set. However, if I change the sample data set to a moderately sized batch of items, the application throws this exception:
Received Log Event (Level: Fatal): WebSocketSharp.WebSocketException: The header of a frame cannot be read from the stream.
   at WebSocketSharp.WebSocketFrame.processHeader(Byte[] header)
   at WebSocketSharp.WebSocketFrame.<>c__DisplayClassa.<readHeaderAsync>b__9(Byte[] bytes)
   at WebSocketSharp.Ext.<>c__DisplayClass9.<ReadBytesAsync>b__8(IAsyncResult ar)
For my tests, it seems the magic number is118 if I don't specify a View. That is, specifying a batch size of 118 items succeeds and 119 consistently fails (throws an exception). For whatever reason, if I do specify a View, the magic number changes to 115.
EDIT: When looking at the ADS log, this is what is produced:
Reason: hipcRead() failed with code 2 and system error 11. Text: <Impl/hipcsrvr.c:2923> Unsupported WebSocket Continuation OpCode
elektron-sdktreprdp-apiwebsocketsrrtobatchexception
@nick.zincone1
I have reproduced this. WebSocketSharp will fragment messages that are larger than 1016 bytes (that value is hard-coded as "FragmentLength" in its implementation). However, the ADS websocket does not support continuation frames yet. We will address this.
@nick.zincone1
This is likely due to a disconnection. When that happens, WebSocketSharp logs this event and the application should get the OnClose event.
Does the ADS log file give a reason for disconnecting you?
@jim.carroll,
I've updated my original post to include the ADS log. Yes, the application does call the OnClose with the reason: "An exception has occurred while receiving.".
