Hello @arnaud.mazzucco
EMA does not provide any method to avoid too many updates. It passes all updates as it receives from the server e.g. TREP(ADS/ADH) to the application. Anyway, TREP provides Conflation feature which can specify the time interval at which updates will be sent. For example, set interval 1 second in TREP, TREP merges all updates e.g. 5 updates received from the feed within 1 second then it will publish as one update to EMA. Then, EMA passes the update to the application. Hence, you can avoid too many updates e.g. from 5 updates to 1 update using Conflation feature in TREP. If you are interesting in this feature, please contact Thomson Reuters Account team.
This methods are applied to ReqMsg objects.
What are the configurations option ?
Like ReqMsg.Timeliness.REALTIME, QosRates.TICK_BY_TICK ?
Thanks a lot
