We are having an issue using the PermId Search API showing erratic behaviour.
For eaxmple, when calling the following API many times in a row:
https://api.thomsonreuters.com/permid/search?access-token=XXXX&entityType=quote&q=ticker:COH AND mic:XASX
Sometimes I receive the correct result:
{ "result": { "quotes": { "entityType": "quotes", "total": 1, "start": 1, "num": 1, "entities": [ { "@id": "https://permid.org/1-55835577616", "hasName": "COCHLEAR ORD", "assetClass": "Fully Paid Ordinary Shares", "isQuoteOfInstrumentName": "Cochlear Ord Shs", "hasRIC": "COH.AX", "hasMic": "XASX", "hasExchangeTicker": "COH", "isQuoteOf": "https://permid.org/1-8590940165" } ] } } }
and sometime we receive:
{ "result": { "quotes": { "entityType": "quotes", "total": 0, "start": 1, "num": 0, "entities": [] } } }
In both situations we receive a status code of 200 (OK)
Is there an issue with the API or rate limiting code?
Regards,
David
