AckMsg Timeout - NackCode NoResponse
Using PostMsg I post a series of data. Each msg have WantAck and a unique PostID starten from 1 and counting up
For each message of the first 149 msg I get a nice response:
AckID: 149 Text : (0) Insert Successful
But for all messages more than that I get:
AckID: 150 Text : AckMsg Timeout NackCode : NoResponse
And then i through LoggerNotifyEvent I get the following:
Received LoggerNotifyEvent: (componentname) static: (severity) warning: "connection_rssl" received unexpected ackmsg streamid: 1 ackid: 150 sequenceno: sequenceno not set
I'm wondering why it seems like it exactly #150 which times out? And is there I way to see if there is to many pendig (if thats the case) and I have to wait before posting more msgs?
Hope for some insight :)
/Jens
treprfarfa-api
For other there may strugle with the same issue, the problem was throttle - I was sending to fast and not waiting in ack msg. For my system the limit was at 10, so waiting to always get ack msg for when PostID-AckID > 10 was the answer
