When we login and do a check, we get a column of source links, where as when we get a API response the source link has some codes, is it possible to get the links as in the login (manual) method?
Hi @akumar,
Yes, when you query the API for the screening results, it returns the name and secondary fields matching info (if provided). To get the match information you need to query each world-check profile match for more information.
Hope this helps,
Brian
