I am using the RFA Java API 8 (8.0.1.E2) to retrieve snapshot realtime and delayed quotes. The behavior I require is for the ADS to return real time quote if a user is authorized for realtime, if the user is not authorized then return delayed quote.
According to the documentation (https://docs-developers.thomsonreuters.com/1493738996143/4730/Docs/WebDocs/wwhelp/wwhimpl/js/html/wwhelp.htm#href=RFA%20Java%20Developers%20Guide/RFAJ_DeveloperGuide.1.112.html) I should be able to use a service group to achieve this behavior and I have designed my solution around this assumption. However I have seen lately that the response from the service group is randomly realtime and delayed. So a user who is set up in dacs for both realtime and delayed for a specific exchange randomly gets realtime quotes and delayed quotes. Is there something missing in my configuration for this? Or is it a missing configuration on the ADS?
Configuration:
_System.EventQueue.batchingEnabled=false
_System.EventQueue.batchsize=100
_System.EventQueue.flushTimerInterval=10
_System.Services.IDN_DELAY.feedName=IDN_DELAY
_System.Services.IDN_RDF.feedName=IDN_RDF
_System.ServiceGroups.ServiceGroupRealtimeDelayed.serviceList=IDN_RDF,IDN_DELAY
fimt.Sessions.rmds.connectionList=fimt::RSSLConnection
fimt.Sessions.rmds.serviceGroupList=ServiceGroupRealtimeDelayed
fimt.Connections.RSSLConnection.connectionType=RSSL
fimt.Connections.RSSLConnection.serverList=*****
fimt.Connections.RSSLConnection.portNumber=*****
fimt.Connections.RSSLConnection.disableDownloadConnectionConfig=true
fimt.Connections.RSSLConnection.logFileName=none
fimt.Connections.RSSLConnection.serviceList=IDN_RDF,IDN_DELAY
