HSBC - Send Get v1/groups - Error 401
Hi, I'm sending a Get to obtain the group id. /v1/groups with a Java Client using HttpClient api.
This is the log I'm sending:
2017/05/03 14:43:14:823 ART [DEBUG] ConnectMethod - CONNECT status code 200
2017/05/03 14:43:14:823 ART [DEBUG] HttpConnection - Secure tunnel to rms-world-check-one-api-pilot.thomsonreuters.com:443
2017/05/03 14:43:14:952 ART [DEBUG] header - >> "GET /v1/groups HTTP/1.1[\r][\n]"
2017/05/03 14:43:14:952 ART [DEBUG] HttpMethodBase - Adding Host request header
2017/05/03 14:43:14:953 ART [DEBUG] header - >> "Date: Wed, 03 May 2017 17:43:14 GMT[\r][\n]"
2017/05/03 14:43:14:953 ART [DEBUG] header - >> "Authorization: Signature keyId="509f9b54-4182-4b56-9284-51020310f2ba",algorithm="hmac-sha256",headers="(request-target) host date",signature="XEEbWlK8hkQ0T98/d1tPZSQWxdLYqLlIa5hkrc0KFSk="[\r][\n]"
2017/05/03 14:43:14:953 ART [DEBUG] header - >> "User-Agent: Jakarta Commons-HttpClient/3.0.1[\r][\n]"
2017/05/03 14:43:14:953 ART [DEBUG] header - >> "Host: rms-world-check-one-api-pilot.thomsonreuters.com[\r][\n]"
2017/05/03 14:43:14:953 ART [DEBUG] header - >> "[\r][\n]"
2017/05/03 14:43:16:910 ART [DEBUG] header - << "HTTP/1.1 401 Unauthorized[\r][\n]"
2017/05/03 14:43:16:911 ART [DEBUG] header - << "Server: Apache-Coyote/1.1[\r][\n]"
2017/05/03 14:43:16:911 ART [DEBUG] header - << "X-Application-Context: bootstrap[\r][\n]"
2017/05/03 14:43:16:911 ART [DEBUG] header - << "Authorization: WWW-Authenticate: Signature realm="World-Check One API",algorithm="hmac-sha256",headers="(request-target) host date content-type content-length[\r][\n]"
2017/05/03 14:43:16:911 ART [DEBUG] header - << "Transfer-Encoding: chunked[\r][\n]"
2017/05/03 14:43:16:911 ART [DEBUG] header - << "Date: Wed, 03 May 2017 17:43:16 GMT[\r][\n]"
2017/05/03 14:43:16:913 ART [DEBUG] HttpMethodDirector - Authorization required
2017/05/03 14:43:16:914 ART [DEBUG] HttpMethodDirector - Authentication challenge(s) not found
Error: 401
Also, I test with the latest version of postman without succedd.
Could you help me please.
world-checkworld-check-oneerror-401
When you loaded the WC1 pilot environment, and collection into Postman, did you try the default Groups call in there. It should work straight out of the box. If that's ok, I'd then check your API and API-secret key values to make sure they are correct in the environment.
Hi @jcgarcia
here's the code Postman is generating for my environment. for this request
Date: Thu, 04 May 2017 12:02:27 GMT
Authorization: Signature keyId="4b99fff9-4b7c-456e-ac7e-c81c709c390b",algorithm="hmac-sha256",headers="(request-target) host date",signature="Xm4RL75+odpK43hyNMLf9KCh9ZbGmLVihRjb66YM9Es="
Cache-Control: no-cache
Postman-Token: 7ce4a315-63e4-c872-59c2-1180984be14c
