how does ongoing screening work for World-check one?
how does the ongoing screening work – I understand the world check re-screening periodically. How often is periodically? And do we need to ask for a re-screening result on a case ID – or do we get advised if any results on a case ID we have?
world-checkworld-check-one
Hi @Bernadette, if a case is set to have ongoing screening then the system will automatically re-screen the case against all updates and changes to the World-Check dataset every day. If you are using the API then you will need to ask for the screen result.
