RFA configuration parameters: service; rsslPort; hostName?
Hi, please help me if you can.
What should I insert into the next RFA conf parameters to be able to retrieve the Reuters Real-Time Marke Data?:
\service = "DIRECT_FEED" ?
\Connections\Connection_RSSL\rsslPort = "14002" ?
\Connections\Connection_RSSL\hostName = "10.67. 4.28" ?
Thanks in advance.
treprfarfa-apirsslServicehosting
7.6k 15 6 9
@dmytro.len
Are you using StarteConsumer example?
If it's StarterConsumer, it has two configuration files.
-ExampleRFA.cfg is RFA configuration
-StarterConsumer.cfg is for application config.
For ExampleRFA.cfg you need to set hostname of the TREP ADS server you are connecting with RSSL port(Default is 14002). I guess 10.67.4.28 is your ADS server.
if you don't know any details about your server, you may contact your infra support team to get the information.
For StarterConsumer.cfg
You also need to know DACS username(userName) to be used for Login and Service name(service) to be used to request. Your infra support team should be able to provide the details as well. "DIRECT_FEED" in our example is default service name which published by Provider example and you have to change it. You may find details about the example from Readme file.
13.7k 26 8 12
@dmytro.len
The connection parameters depend on your data feed configuration. To get the appropriate values you need to ask the person in charge of your real-time data feed. In case of doubt, contact your Thomson Reuters Technical Account Manager.
