A couple of questions ...
Hi there,
I have a couple of questions I was hoping that someone could answer:
How do I archive a case via the API?
Is there a way to detect when a result has been automatically resolved? I'd like indicate whether a result has been manually or auto-resolved when I'm showing results.
Is there a workflow for setting OnGoingScreening to be true? If I set it at the same time as creating a case / screening case then I get no results - if I turn off OnGoingScreening I get results but I'd like results and ongoing results.
Many thanks!
world-checkworld-check-one
3.1k 16 7 7
Hi @stephen.davidson,
The WC1-API does not support Archiving cases (yet).
Yes, you can screen a case then check the resolution is NOT null, and then the statusId for the resolution is not null with the resolutionDate field null (i.e. Check if any of the other (mandatory) fields are null. ... For this example, (using the Sample Group setup, which forces the user to fill out all the fields, except remark) when I screened a case, some of the matches were auto-set to statusId=False, but riskId, reasonId, and resolutionDate are null, so this must have been auto-resolved by the screen.
Hope this helps,
Brian
(I'll have to check on OGS setting and screening)
    "resolution": {
      "statusId": "36604ead-d000-4111-ae10-e23d2bcfc7db",
      "riskId": null,
      "reasonId": null,
      "resolutionRemark": null,
      "resolutionDate": null
Great stuff - thanks for that - much appreciated.
Hi there,
Was there any progress on the OGS / Results issue?
Many thanks
