hmac sha 256 in Salesforce?
I'm trying to implement the hmac sha256 example from the documentation in Salesforce Apex, but I am not able to reproduce the base64 value.
This is the example HTTP request from the documentation:
POST /v1/cases HTTP/1.1
Host: rms-world-check-one-api.thomsonreuters.com
Date: Tue, 07 Jun 2016 20:51:35 GMT
Content-Type: application/json
Content-Length: 88
  "caseId": "my customer ID",
  "name": "John Doe",
  "providerTypes": ["WATCHLIST"]
According to the example, the following input should be used for the hmac function:
(request-target): post /v1/cases
host: rms-world-check-one-api.thomsonreuters.com
date: Tue, 07 Jun 2016 20:51:35 GMT
content-type: application/json
content-length: 88
  "name": "John Doe",
I implemented the function (as shown below), but keep getting different values. I even tried to alter the spaces and the line endings, but never matched the value, which is shown in the example:
"Given the above signing text, if a secret key of “1234” is used, the computed HMAC-SHA256 value would beDA26D7F5BFF89A100D1A597AA015099FC55DD3130F023E952BFBE3A6949F322A when printed using hex encoding, or2ibX9b/4mhANGll6oBUJn8Vd0xMPAj6VK/vjppSfMio= when printed using base64 encoding."
String testString = '(request-target): post /v1/cases\n'
+'host: rms-world-check-one-api.thomsonreuters.com\n'
+'date: Tue, 07 Jun 2016 20:51:35 GMT\n'
+'content-type: application/json\n'
+'content-length: 88\n'
+'{\n'
+'"caseId": "my customer ID",\n'
+'"name": "John Doe",\n'
+'"providerTypes": ["WATCHLIST"]\n'
String testKey = '1234';
String algorithmName = 'HmacSHA256';
Blob hmacData = Crypto.generateMac(algorithmName, Blob.valueOf(testString), Blob.valueOf(testKey));
return EncodingUtil.base64Encode(hmacData);
In this case, the base64 value was "V9d9dkg2aS1J0P/7GVPdC34ddLMdrRixtt6mf9xsJ+Q="
Line endings should be fine, according to the Salesforce Apex Language Reference. \n should be a LF Line ending.
Source: https://resources.docs.salesforce.com/sfdc/pdf/salesforce_apex_language_reference.pdf - Page 29
Salesforce docs show, the used method is fine: Crypto.generateMac
Source: https://developer.salesforce.com/docs/atlas.en-us.apexcode.meta/apexcode/apex_classes_restful_crypto.htm
Do you have any idea what is wrong here? Do I have an error in my spacing or something like that? I just want to implement the example in Salesforce Apex Code.
Thanks in advance.
world-checkworld-check-oneapidocumentation
3.1k 16 7 7
Hi @raphael.rugova,
I recreated the example in the Documentation with special attention to detailing exactly how I got my results....
I attached a screen shot of what I did... a couple Notes:
  1. The body of the message uses Unix LF and not DOS CR/LF (it's documented but easily overlooked if you cut&paste the example.
  2. I use Notepad++ to view the message. This helps by showing there are 2 spaces before some of the lines and the LF, plus the count of bytes to confirm I've correctly copied the message body
  3. I use Visual Studio C# to produce my results, using the HMACSHA256 code example from the Microsoft Documentation, see code below.
Hope this helps,
Brian
        // Combine the data signature and the API secret key to get the HMAC
        // This is the Microsoft HMACSHA256 code copied from the documentation
        public static string generateAuthHeader(string dataToSign, string apisecret)
                byte[] secretKey = Encoding.UTF8.GetBytes(apisecret);
                HMACSHA256 hmac = new HMACSHA256(secretKey);
                hmac.Initialize();
                byte[] bytes = Encoding.UTF8.GetBytes(dataToSign);
                byte[] rawHmac = hmac.ComputeHash(bytes);
                Console.WriteLine("---rawHmac---");
                string hex = BitConverter.ToString(rawHmac).Replace("-","");
                Console.WriteLine(hex);
                return(Convert.ToBase64String(rawHmac));
Thank you, that solved my problem completely.
3.1k 16 7 7
Hi @raphael.rugova,
The World-Check One API documentation has a misprint. I will post an update shortly.
Sorry for any inconvenience this may have cause you.
Brian
