Whenever I run a PHP script that connects to the World Check API, the first request made always takes a lot longer than the following requests. For a script that makes 9 requests, here are the times taken and the HTTP response codes
- 60 seconds (200)
- 0 seconds (200)
- 0 seconds (200)
- 1 seconds (200)
- 0 seconds (200)
- 0 seconds (200)
- 1 seconds (200)
- 1 seconds (200)
I don't believe this to be a caching issue as I get the same results with different requests. Occasionally the first request will return a 401 but the ones after will return 200
I am connecting to the Pilot server for these requests.
Any help is appreciated thanks,
Craig
