I am trying to connect a UPA Consumer to a specific endpoint and when I run the connection and initialization I am getting the following: Error RSSL_RET_FAILURE (-1) (errno: 104) encountered with rsslInitChannel fd= 7. Error Text: <Impl/ripcsrvr.c:5912> Error: 1002 Could not read IPC Mount Ack. Connection attempt has failed. System errno: (104) Then endpoint is currently able to run and get data with an RFA. So would there be an issue with the configuration of the endpoint to allow for OMM to communication with port trying to be used.
