Currently i have a Datafusion instance with OA data, i want to know how can i have permiID PA (people Authority Data)
DF URL :http://54.234.74.18/datafusion
Please reach out to Brian Rohan to have this data provisioned via Graph Feed.
hi @kamran.shams, thanks for getting in touch. I have created an entitlement for you to the content set People permid data via the Graph Feed. You should receive credentials by email to allow you to download this content set and updates. Get in touch if you have any problems. Brian
@brian.rohan
Quick question
I was able to download ID 15 (people data) from the api and uploaded it to my DF instance but still I am not able to see people data
Please help.
Regards
Kamran Shams
@brian.rohan i am still not able to see the people data, i followed the API guide but as per above screenshot i am not able to see the data can you please help?
@kamran.shams You have successfully imported the RDF. Have you assigned Master Entity Type (eg Person) and at least one Label? The data will not be indexed otherwise. Stitching to PermId is also available, but not automatic. There is more information here. Please let me know if you've already tried this without success and I will try to help more.
Please see the documentation at http://docs.datafusion.thomsonreuters.com/dfgf how to set up the DFGF connector once you have the credentials.
