RFA to download dictionary and save as a re-useable local dictionary
Is it is possible for RFA to download dictionary from ADS/ADH and save that dictionary for local use next time the app runs?
treprfarfa-apielektron-data-dictionary
Yes, it is possible.
RDMFieldDictionary provides functions (encodeRDMFieldDictionary() and encodeRDMEnumDictionary()) to encode Series from RDMFieldDictionary. After that, the application can write the encoded buffer of Series to binary files.
#include <fstream>
void Consumer::processDictionariesComplete()
rfa::rdm::RDMFieldDictionary& dict = getRDMFieldDict();
rfa::data::Series rdmSeries;
rfa::data::Series enumSeries;
//Encode dictionary to Series
dict.encodeRDMFieldDictionary(rdmSeries);
dict.encodeRDMEnumDictionary(enumSeries);
ofstream rdmFile("rdmfield.bin", ios::out | ios::binary);
ofstream enumFile("enumtype.bin", ios::out | ios::binary);
//Get Encoded buffer of Series
const rfa::common::Buffer& rdmBuffer = rdmSeries.getEncodedBuffer();
const rfa::common::Buffer& enumBuffer = enumSeries.getEncodedBuffer();
//Write encoded buffer to binary files
rdmFile.write(reinterpret_cast<const char*>(rdmBuffer.c_buf()), rdmBuffer.size());
enumFile.write(reinterpret_cast<const char*>(enumBuffer.c_buf()), enumBuffer.size());
rdmFile.close();
enumFile.close();
Then, the application can read those binary files and set the encoded buffers to the Series and then use RDMFieldDictionary::decodeRDMFieldDictionary() and RDMFieldDictionary::decodeRDMEnumDictionary() to decode the Series.
char* Consumer::ReadAllBytes(const char* filename, int* read)
ifstream ifs(filename, ios::binary | ios::ate);
ifstream::pos_type pos = ifs.tellg();
int length = pos;
char *pChars = new char[length];
ifs.seekg(0, ios::beg);
ifs.read(pChars, length);
ifs.close();
*read = length;
return pChars;
void Consumer::DecodeDictionaryFromFiles()
rfa::rdm::RDMFieldDictionary& newDict = rfa::rdm::RDMFieldDictionary::create();
rfa::data::Series rdmSeries, enumSeries;
rfa::common::Buffer rdmBuffer, enumBuffer;
int rdmSize, enumSize;
char* rdmSeriesData = ReadAllBytes("rdmfield.bin", &rdmSize);
char* enumSeiresData = ReadAllBytes("enumtype.bin", &enumSize);
//Set binary data to the buffers
rdmBuffer.setFrom(reinterpret_cast<const unsigned char*>(rdmSeriesData), rdmSize);
enumBuffer.setFrom(reinterpret_cast<const unsigned char*>(enumSeiresData), enumSize);
//Set buffers to Series
rdmSeries.setEncodedBuffer(rdmBuffer);
enumSeries.setEncodedBuffer(enumBuffer);
//Decode Series with RDMFieldDictionary
newDict.decodeRDMFldDictionary(rdmSeries);
newDict.decodeRDMEnumDictionary(enumSeries);
delete rdmSeriesData;
delete enumSeiresData;
Hi @Akechi Sato
As you may know, changes are made to the dictionary as & when required by Thomson Reuters e.g. there have been 5 dictionary service packs released in the past 6 months to add new Fields and update/add Enumeration types.
If the application consumes data which contains a new Field that does not exist in the local cached dictionary or if the definition of the field or list of enumerated values have changed, the application could experience a problem.
Please make your client aware of this.
