Ema News feed - Auto reconnection not happened
Hi Team,
We are running Ema C++ news component for news feed.
Yesterday the component got disconnected from the server and auto reconnect does not happen.
Please check the logs below,
loggerMsg
TimeStamp: 13:35:43.889
ClientName: Consumer_1_1
Severity: Error
Text: EMA Exception Handler
Application: EMA Application
Process Id: 0x7843
File: Impl/Thread.cpp
Line: 71
Exception occured
loggerMsgEnd
Please help me enabling the auto reconnection.
Thanks,
Thiruppathi S
elektronrefinitiv-realtimeelektron-sdknews
The limited log output does not suggest a controlled disconnect - it could well be an application level problem.
If the network connection was lost or if the ADS server shutdown of if a service was down, you would get a more meaningful message explaining the loss, and the API would attempt to recover once the network/server/service was restored.
Once you do figure out what went wrong, I would recommend you use a ChannelSet - if you are not already doing so. See the EMA config guide for details and also the following post Example ChannelSet config
Hi @umer nalla
We have added xml trace option in EmaConfig.xml file and found the connection is closed and reconnection not happened.
XML Trace output:
<!-- End Message (Channel IPC descriptor = 12) -->
<!-- rsslCloseChannel Connection closed (Channel IPC descriptor = 12) -->
Exception Thrown from the application
loggerMsg
TimeStamp: 2017/03/24 04:32:47.873
Severity: Error
Process Id: 0x5D7F
Line: 71
Exception occured
loggerMsgEnd
Please help in this.
Thanks,
Thiruppathi S
