Supplying a empty or {} body returns nothing. {"filter":null} seems to work. Can you confirm that returns all events.
Hi @Fran Dugger,
The documentation is a good place to start for questions
The enumerations are documented, use swagger and in the YAML schema (lines #3306 & #565) v2.0.
e.g. actionType=='ASSIGN_CASE'
OR
actionType=in=('ASSIGN_CASE', 'NEW_MATCH')
No actionType will assume all actions.
Hope this helps,
Brian
