I have set up a launchpad instance on AWS, and being unaware of the restrictions, have used the AWS tr-sandbox environment.
I now need to go through the process again to set up in the non-production environment, instead, I believe. However, I'm unable to delete the launchpad instance I have already created. When I attempt to do so via the launchpad dashboard, I get a notification that my AWS keys have expired or are no longer valid.
I'm using keys newly generated using the process described here, https://thehub.thomsonreuters.com/docs/DOC-1728333, but to no avail.
Any help in removing the instance would be appreciated.
Many thanks!
