cancel trade or irregular trade
There was a cancel trade for RIC:HCEIF7 ~07:50:11 GMT this morning. I just want to check what the FieldLists are, at the time to denote a canceled trade. Is it possible to get a screen shot of the fields at that time and may be some advice to handle irregular trade in general.
thanks
treprfarfa-apitrade
4.4k 10 6 9
As far as I am aware, cancelled trades are not sent through the HKFE feed.
Usually, FID 372 (IRGPRC), 1023 (PRNTBCK), & 4221 (IRGPRC2) would indicate a cancelled trade, however these FIDs are not in use for HKFE.
You should double check this with TR data support help desk via https://my.thomsonreuters.com/ContactUsNew
Lastly, is it possible to view list of supported FIDs for each exchange?
Yes, there is a web application for that.
https://developers.refinitiv.com/en/tools-catalog?type=dev-tools-menu-11605
https://datadictionary.thomsonreuters.com/Public/Login.aspx
Please contact your Technical Account Manager for access.
Ok, I will check with TR data support. The specify irregular trade is verified against Bloomberg terminal as 'cancelled'.
@Warat B. we are using java electron API to get the real time TR (FINRA trace) feed. I have similar question, i want to know trade events like REGULAR TRADE, TRADE_CANCEL, TRADE_CORRECTION, PRIOR_DAY_TRADE, PRIOR_DAY_TRADE_CANCEL, PRIOR_DAY_TRADE_CORRECTION, TRADE_NON_REGULAR. Is there any FID# with flag indicates type of trade event. I want to process logic as per trade event, please let me know if there is also any other way to find these trade events.
